Thanks for the design was looking at a v-ed block & a pointed punch to go in a vice as a method.
you can buy the crimps with a lump on the side all ready to be punched in
I have bought a set of those.you can buy the crimps with a lump on the side all ready to be punched in, if that helps.
. Worked with a hammer but took a LOT of pounding., sort of thing a fitter would use, I'm an electrician with a bit of pride in my work![]()
i always knew i would meet a sparks with pride in his work.trust him to b on a mechanical forum
.........u threw the first stone
shenion;66395........ Since then I have made my own out of 5/8"OD flexible copper pipe. Cut about 3" said:I've done the same, quick, cheap and effective.
I've also used copper brake pipe to crimp several wires together when re-wiring my Landrover.
Don't know much about them but isn't laser more accurate and cleaner cutting than water jet? + there's got to be a lot less mess!Ahhh, but isnt laser just poor mans water jet,![]()
