Hi guys.
Today I dropped my gas regulator valve whilst moving my welder about, and have snapped one of the brass fittings. The rest of the set up is okay as it was a light(ish) impact but one of the brass fittings has a thin end on it that has snapped off.
Below are some pictures of the part (sorry for the fuzzy resolution, they were taken with a phone at close proximity)
On the first image, a small thin pipe should protrude (you can just about make out what is left of it). This pushes inside a standard gas hose (I'm not sure of the exact size but it is pretty thin, approx. 3~4mm internal diameter)
Does anyone know the name of this fitting so that I can order it, and also perhaps a place from which I can order it?
Thanks, Sam.
Thanks, Sam.
