Mid Wales welder
Welder coding and NDT services
- Powys, U.K.
Hi all, does anyone know where I can find a MAG welding settings chart witch shows amps, volts, travel speed and maybe even heat input for given thicknesses of steel, and for each joint type. I need it for working out WPS's so needs to be accurate, although I will test them in the workshop just to check its all right. The Miller calculator only goes up to 12mm thick. Thanks in advance.
