malcolm
& Clementine the Cat
- Bedford UK
Inspired by the last post in rtbcomp's switch positions thread:
My thought is if you up the volts and the resistance stays the same then the amps will go up so more metal can be melted. (Dr Ohm, his law, and all that).
The only way the amps could go up for the same voltage is if the wire got less hot, or the arc gap got smaller. Although that would probably happen to an extent if the wire speed was turned up. I'll move on quickly in the hope that doesn't defeat my argument.
My take on wire speed is it's something that should be set to suit the power setting. Low wire speed for low power setting and high speed for a higher setting. But there does seem to be room for maneuver: for welding end on to an edge I've found I can reduce the current by slowing down the wire feed and holding the tip very close to the workpiece (shortening the arc? - but that makes no sense). Overheats the tip but the welds are neat.
Any ideas on this?
This one has been bugging me for ages. Some welding Overlord once described the power knob on the welder as the thing that controls the voltage (which it does) and then went on to describe the wire speed as the thing that controls the amps (which it doesn't in my view).I didn't realise that rate of feed affected the welding current
Any ideas on this?
but I think you'll find that as MIG has constant voltage so the amps will alter dependent on the length of the arc. As wire speed can be thought of as setting the arc length so it 'appears' to be controlling the amps.
