Pollys13
- Wiltshire UK
My compressor manual says, " Your compressor is ready to accept air hoses with uni adaptors into the spring quick outlet coupler. "
The 5M Draper air line I bought has 13mm ID and 21mm OD comes with 1/2" BSP male fittings. What type of adapter do I need to connect the air line to the compressor? This might be just one end,
as I've read to keep the air line as short as possible to reduce or prevent any moisture build up
? So if doing this, is a good idea? How do I cut the hose, sharp heavy duty scissors, do a good enough job?
How do I fit a new connector onto the severed end, what type, an adaptor?
Cheers.
Cheers.
