brightspark
- yarm stockton on tees
the answer to grinding holes to get in can be overcome by laminating behind the door with plywood then steel sheet grinders do not cut woodWent to a set of lock-ups a couple of months ago and some rat had cut a perfect 3ft x 3ft hole in the bottom corner with a cordless grinder and 1mm disc...something to think about regarding putting plate on the inside before you go down the locks route![]()
desperate times if they steal compost and plant pots
and the odd trowel
