- SW Scotland
Good call Bill, had totally forgotten about them. Look just the job for inside the new machine.It still rusts.
And then the rust ruins the liner, so the next thing you know is that you need to replace the liner, tip and probably reel of wire, unless you have the patience to manually pull off enough to remove every bit of the top layer that's showing any sign of rust.
PITA.
You can get tiny heaters such as http://uk.rs-online.com/web/p/enclosure-heating-elements/2995714/ which could be used to keep gear slightly warmer and ought to help.
