Finalreminder
Professional amateur
- Denbighshire
Can you weld or braze steel fittings to brass fittings?
I did try brazing once and managed to achieve nothing at all.
A complete zero result with 5 brazing rods.
) coat the steel with flux. If possible heat from the opposite side to stop the flux burning and introduce the solder. The more tin in the solder the easier it is to tin the steel.
(remove any zinc or you'll get zinc poisoning)
seem to remember using boron based flux... forgot the full chemical name now though
