Hi everyone
First post on the forum, although I did register a few years ago ! I did an 'Intro to Welding' course at a local college, where I spent several weeks welding small pieces of 2.5-ish mm with arc, mig and some gas on thinner steel. I got on with the Mig welding OK, and was looking at it ahead of starting some welding on my classic.
I have a 1976 Stag and some filler dropped off today, revealing holes and rot in a structural place around the windscreen frame. This is a common fault with the car, and the Stag owners forum has threads of how to repair, and this looks to be with 0.8mm and 1.00mm steel. I would expect this is the thickness of steel I will be most commonly welding, as I would like to make up repair panels, stepped into the existing bodywork or fit pre-shaped repair panels. I'm not planning on getting into chassis welding at this point.
Welder-wise, I am not sure what to go for so looking for some advice - my usual first website for automotive tools is MachineMart, and I have found the Clarke 151TE -this looks to be a best-seller so lots of people must have thought it looks half-decent also . I am open to suggestions, but this is for a hobby, not a profession.
I am looking for one that will work off a standard (UK) domestic supply , I expect to have a 'gas' one , rather than a 'no-gas' ( unless the overwhelming view of the expertise here is that 'no-gas' is the way to go.
What suggestions can you make for this newbie ?
Thanks in advance
Malcolm
Thanks in advance
Malcolm
. I have the auto-darkening mask already and a long glove somewhere.
