atomant48
- Salisbury, UK
As above. I had to replace the struts and springs on my car last week. This is the second time I've done it (ie second car) and both times I've had the same problem - how to hold the strut "rod" - it has an internal hex thread - while loosening/tightening the main nut. The issue is the nut is in a deep recess and although a deep socket easily fits you can't then get a hex key in.
I've managed both times by cutting a socket in half and welding it to a piece of steel bar with a hole drilled in to line up with the socket. This gives a hole to pass the hex key through and it works a treat. Issue is that this car was different size socket to the last one so I don't know how long my socket set will last!
Anyway after a bit of google action it looks like a "pass through socket" is the answer - they have an external hex on the socket rather than a square drive and then a thing like a ratchet spanner is used to drive the socket.
Is this what other people use or is there another way? I'm guessing a rattle gun might spin the nut without turning the shaft but I'm not sure how you'd ever know it was tight ?
