knoba
...break a leg!
- Sussex, England
I'm building myself a decent, all-rounder, metalwork bench out of stainless steel (approx.: L2.4m x W0.6m x H1.0m). Before I brazenly purchase a TIG can anyone tell me how well my MIG will do the job? Or give me any indication on the best setup to see how good it can get.
All the S/S is 1.4301. The main framework is 50mm x 50mm x 2mm square hollow section. I have some 6mm x 50mm x 50mm S/S equal angle, which also needs welding, to reinforce the top edges, and some 2mm sheet for the surface worktop. I want to weld in S/S bolt sleeves to reinforce the square hollow sections and also weld in S/S captivated nuts too. I want to do a "really nice" job of it.
The MIG is a Murex Tradesmig 210. I was told 308L filler wire (cited by Parker steel) and Pureshield gas (cited by BOC).
Assumptions remaining;
Wire thickness and filler type?
welding techniques?
Shielding gas?
Will tungsten carbide burrs, HSS Drill bits, 1mm Norton cutting discs & fibre discs handle/contaminate the S/S?
Special liner/rollers for the MIG?
All the other things I don't know, because... I don't know; I don't know them
Any input gratefully received...
welding techniques?
Shielding gas?
