the snooper
getting older by the day
- Hull UK
are the compressors you are looking at belt drive or direct drive ? the direct drive are very noisy belt drive are far better machines
for 3mm stick with the plasmaYes, it means chassis work unfortunately !
I'd bet they're at least 4 times better too. Could you get a nice big second hand one?Awesome answers everyone thanks. Yes, Snooper it will be a direct drive. The belt drives seem to be a lot more expensive. I saw one 3HP belt drive and it weighed 80kg ! I am looking at £100 ish and those machines are more like £400.
yes they are more expensive but better, start thinking along the lines of building a simple cover to kill the noise, they drive you madAwesome answers everyone thanks. Yes, Snooper it will be a direct drive. The belt drives seem to be a lot more expensive. I saw one 3HP belt drive and it weighed 80kg ! I am looking at £100 ish and those machines are more like £400.
Well done maker thats what I thoughtThe link for the 3hp one says "input power: 1500W", 1.5 kW is 2 hp, not 3. I don't know how the output power has been calculated but that's closer to 1 1/4HP. I don't think I'd bother with one of these.
.Well done maker thats what I thought7.5 cfm ??especially only running up to 115psi, which is very low, my compressor kicks back in at higher pressure than that.
Maker you sure your 15??.
I'm well impressed
3 hp should be 2250 ish W
http://www.engineeringtoolbox.com/horsepower-compressed-air-d_1363.html to give you an idea
plus I'm going to be working quite a way from the nearest plug scocket and it sounds like the higher power motors with the 100litre units won't like being fed through extension leads.
So here's two pics of the spec plate off the air compressor. It does look like 3HP as they said and the power is 6.5x220=1.43kW
Any ideas ?
I concur. Unless they've bent the laws of physics, that's nae a 3hp compressor.I'm still not convinced, it says the current is 6.5A which means the power cannot be more than 1560 watts, ~2HP but it will be less than because of energy lost to inefficiencies. According to this page, a 6.5 amp motor is going to be more like 1HP.
they do use 3 horses-------accept two of them have been hobbled.And if it was, I'd be wondering what stable the lazy third horse was lying down in, if it was only generating 7.5cfm![]()
