Richard.
- Cambridgeshire
Even with the welds nice and flat the end plates don't look good unfinished. Mitres look tidier if the joint is to be left as welded in think so any way.If your welding is good enough there's no difference between leaving the weld on a cap or the weld on a joint. Knock the wire feed and power down to an appropriate level and you're fine. The type of joint makes no difference if the welding is cack.
