SpitfireIV
- Ireland
Hi all,
First time poster here, but long time lurker, sure learned a lot from the articles and forum questions, but, I have one of my own now that I hope someone can help me with.
I'm working on a MkIV Spitfire, total and utter rebuild from the ground up. Just yesterday, things going great I applied UPOL Gravitex to the underside of the tub, which, in no time at all began to lift the rust primer I had applied under it, little wrinkle here and there at first, gradually getting bigger until the stonechip and rust primer could be peeled off like a soggy, solventy tissue paper......damn.
Rookie mistake, the rust primer I used was oil based I believe (thins with spirits) and the Gravitex is cellulose based (strong stuff apparently and a bloody good paint stripper if nothing else!) The rust primer was applied in early Jan, I scuffed it up yesterday, cleaned and wife it down before applying the stonechip.
So, I've had to strip back the underside to metal and will take another approach having learned dearly my mistake.
Now, to my question, or, my concern. Over the past few months I've been carefully cleaning, treating and painting the interior of the tub, section by section; floorpans, boot, bulkhead etc etc. Treated with Deox Gel, then applied Hydrate 80 and then, once more I used this oil based rust primer to paint the lot, two coats in fact with seam sealing in between!
Oh oh! My plan is to use cellulose to paint the car; DIY job. Was planning on giving the inside a blast of primer and then the topcoat, but, obviously the primer is cellulose based and I fear A. all my work has been in vain and B. the inside of the car could resemble soggy tissue in no time!!!
Q. Will a bar coat applied over the oil based rust primer allow me to carry on then with the cellulose based or do I have to strip the whole lot back and go back to square 1?
Thanks for any help at all guys!
