Hi I hope someone can help or guide me in the right direction.
Below is a couple of photographs of some Aluminium pipe which I'm practicing on. The thin bit is cut from the large bit so they're the same material.
I've then cut through the thin bit, gave it a quick clean and scrub with wire brush and it's welded (please ignore the state of the weld)
I've done exactly the same to the larger part (but cleaned it for a lot longer) and it won't fuse, won't melt and obviously won't accept filler. I presume this is the oxidant scale which people go on about.
Cleaning is done with Acetone and then wire brushed with a stainless brush. Like I said, one part is welding, the other won't. It's exactly the same material any ideas as to why?
Could it be that the larger part isn't getting enough heat?
Material is 1.6mm thick by the way.
Using 45 amps 60hz (ish)
