darren.a.roberts
Range Rover Classic - front bulkhead mount has rotted through so it's got to be fixed for the MOT. Really after some advice as to the best way to tackle this one.....
Got a new mount from YRM which is made of heavy duty zinctec steel (looks like about 2mm). I've already moved the brake lines but I've got two fuel lines running right underneath it between where the mount needs to be welded and the chassis.
Should this be plug welded or seam welded (the original looks like it was plug welded) ? The nearside looks like it would be fairly easy to get to but what about the underside and far side - doesn't look like there is much room.
The bulkhead is only 1.2mm so the usual challenge of different size materials.....oh joy of joys....
Any suggestions appreciated.....
