Pete.
- Kent, UK
1 bar wouldn't show anything. Atmospheric pressure on the ground is 1 bar
Yeah but 1 bar gauge is 2 bar absolute. The compressor shows gauge pressure so you're still a bar in credit.
if your lucky
your going to need a fair size compressor to fill a mile long pipe with sections of 2" especially if it has got various leaks.
if the water leak has not shown at the surface (nominal 4-8 bar) I dont think there is a hope in hell of air doing so
you could try a pipe clamp to close off sections but it can be tricky if the pipe is not in good condition and/or cold...... 2 round bars... at this size I would guess 1.5-2" dia, bolted together to crush the pipe..
if the water is still on, or can be turned on I would use a listening stick and walk the pipe from the point of origin stopping every 5-10 paces and listening for the leak(s)
if the supply is on a water meter a mile away and u know where the pipe run is find it in the middle and fit a stopcock . check the water meter and it will show which side the leak is then as pete says dig up and quarter it fit another cock and narrow it down again
There are literally miles of pipe feeding upwards of 50 cattle troughs here. I feel your pain. Yearly there's some kind of leak to sort.
Firstly, how old is the pipe? If its not the new blue stuff, stop chasing your tail and start saving for replacement. The old black pipe deteriorates with age and can't stick the pressure. If you have this and can't afford to mole in a new line now, look in to buying a pressure reducer, it should stop the pipe busting pressures that build up overnight.
One of the best things you can use when on leak detection is a water meter, you can buy them but they are dear. (£70??) Plum it in at the beginning and shut off your house. Shows you the volume of water your looking for and if you do the halving method described above will give you confidence about your decisions. Put it in a length of pipe and take it with you, insert it inline whenever you dig a hole, the flow rate data you get it is very helpful.
I've never tried using air for leak detection as you can generally spot the leaks rising, especially when you know where the pipes lie and know the land (without leaks). This is trickier on really wet or very free draining ground though. However, we do use a road compressor to "blast" air through the pipes routinely to remove sediment from the unfiltered well supply. Decent pipes should withstand it.
Listening sticks work best under firm ground or concrete.
It sounds like a pig of a job, the best of luck...
If the leak is in the big pipe which is quite probable, could you not run smaller pipe down the centre of old and save a load off digging you would only have to dig and cut old pipe at the end of your rolls?
That's an idea with trying in the 1 1/2" bore stuff perhaps
Alkathene connectors have an insert in the pipe end. You'll be lucky to push a new pipe through unless you dig up all the joints.
The meter measures flow rate, so long as you can connect it up, bore size is irrelevant.
I don't want to pooh pooh someone else's idea but don't expect to be able to push any length of alcathene inside each other, I've tried with 3/4" into 32mm. After just a few metres it gets incredibly resistive. You may be able to draw it through but I wouldn't like to guess the max length before you get to the ultimate tensile strength of the pipe you're pulling...
To be honest, this system all sounds a bit broken, what with the leaks, varying pipe sizes and the fact it was designed in such a way that your neighbour was able to starve your supply.
Another, probably useless, outside the box suggestion; you're on wetish land? Find a spring and create your own supply closer to home?
! if the stop proves it to be his house with a busted pipe I will swap out the stop end with a valve and let him deal with it on his return then he still has water to his outside horse trough at least as soon as he can turn off the house stop cock.
Update
Pumped near 2 bar in from my house end and walked the run nothing seen or heard to the point I cut the line and found good flow previously. Interestingly the line pressured up real quick (the water cant be far away) on removing the pressure a got a big flow back of water that came hurtling into my tank then stopped. I must have pushed the head of water back creating a fall back pressure I suppose.
and start from the meter end . and if no gauge check the meter for flowYou pressurised the line and the air being lighter went uphill allowing an amount of water between you and the air pocket. You're not going to prove much like that, what you need is valves and a gauge. Pressure up the line, shut off the air and watch the gauge for falling pressure. That's what will find you your leak.
