Bill Edwards
- Scarborough, North Yorkshire
Yes, there is a big difference between managing to run a 4mm rod and welding with a 4mm rod. Doing the latter off a 13a fuse isn't really doable.
3.2 does do fine for most jobs and a 13a supply shouldn't blow too often in normal usage. If you're doing a lot of heavy work where too much time is being wasted using multi runs with a 3.2 and therefor need a 4mm then sorting out a better supply isn't likely to be difficult, you're then a step up from hobby, general farm jobs etc.
