phill d
- slough, berks , England
Hi guys, to some of you this is probably silly questions that anyone should know, but I don't
so I am asking those that do know....YOU folks.
I know the slower the better when drilling stainless and been told to put on lots of pressure.
But what is considered lots of pressure ??? I have an Elliott progress 1bench drill and will be
drilling stainless propeller hubs.
these are around 6mm thick and will eventually be needing 3/8th and 1/2 inch holes for prop venting.
So what I need to know is, just how much pressure should I put on the levers to pull down the chuck etc.
is it a case of a bit of pressure or a case of pull it as hard as I can ?
I don't want to bust the drill etc.
ive never used bench drill before this weekend, so this is all new to me. especially the stainless drilling.
ive have a few good drill bits and keep them very sharp.
I will be drilling at around 320 rpm with 1/4 bit after I get through with a 1/8 pilot hole, then 6mm and finnish with a 10mm before
testing to see if I need to go to 12 or 13 mm .
picture below
this shows vent holes already drilled on this prop, this is the same as I want to drill.
phill
picture below
phill
