BomberJohn
New Member
- Liverpool, UK
Hi. I am a total newbie, so please be gentle! I have a small hole in an alloy cylinder head (cam bearing cap bolt sheared, then drilled out).
I figured I'd fill the hole with hts2000 and then use a helicoil kit to replace the thread in question. If I'm going to re-tap the thread I might as well over engineer it! My question is this- the hole is about 10mm across and 20mm deep. How can I best 'tin' the hole sides prior to filling? I'd thought of cutting out some alloy from the side to improve access and then filling the lot, but this seems extreme!
