SmartWerks
pre-moderated
- chester
Thinking about it, I'm going to use soldered joints. A lot cheaper and maintenance free and should be less prone to failure.
I've never seen those before! They look pretty poop though, they remind me of electrical connections we used to get on American machines from my previous company.http://www.screwfix.com/p/ideal-twister-341-twist-on-wire-connectors-pack-of-100/63342
Those are wire nuts...horrid things and a major cause of electrical fires in the usa....but they still keep using the horrid things
Silly question but.....has anyone thought of using a small radiator for the condensation trap line instead of piping?
Ones like those upright bathroom stainless steel type.....mind you copper pipe will be cheaper. :-)
Car rads are usually only rated to what, 2bar? house rad sounds a good idea, though even if you use plastic pipe a copper coil could be put inline to aid cooling and condensing.
i have a couple of myson wall convector radiators with fan blowers on them. there 15mm and will take the pressure i just cant be bothered to conect one up though
lazy old sod. Stainless steel wouldn't be a good choice for a cooler as it doesn't radiate heat very well?
If the stainless steel rad doesn't radiate heat very well then why do they use these rads in bathrooms? I do feel I should get the housing to change mine as it doesn't seem to heat the bathroom up very well and believe it or not its a very small room,something like 6ftx6ft? and in winter its still coldish for getting a shower.
Any evidence for backing stainless rad up as a poor radiator to install in the bathroom so I can sling it on their desk for confirmation to change it.View attachment 58976
its more of a towel warmer in the bathroom and take the cold air off the room
I've always preferred soldered joints over unions or push fits. They all work in general use, but I personally just trust soldered joints more.
u still need to add a dab of solder on the yorkshire fittings even though they have the solder ring , u need a nice clean pipe and fittings and use an acid flux as wellThat was my feeling, lot bloody cheaper too!
I seen some ring fittings which i think are also called Yorkshire fittings that have a bead of solder, i think these will be better for me. I've only soldered once before and made a good job but them ring fittings look like a simple piece of kit?
