brewdexta
The biggest tool in the box
- UK
Well, I bit the bullet and bought a Brymen, plus a couple of spare sets of silicon leads and the monitoring software/dongle, a bit more than I budgeted for however given that these things should last a good while then I thought it was worth it. There were a few features that I seemed likely to use I ended up with a top end device for a similar price as a mid range Fluke with what looks like comparable build quality. Obviously there's not as many about so not the same dealer network/spares but that's a risk I'm willing to take. I'm not a pro, if I was I could justify spending more and get a Fluke/Agilent etc. as turn around time when you wanted it fixing would be paramount.
This is the one I ended up with (the BM869) when it arrives from Poland from here, I have a few Polish mates who can chase things if they go Pete Tong however they seem to have been around since 1990 so I don't envisage any issues.
The Fluke turns out to be a BT special based on an Fluke 8020A. I think BT messed about with the leads as I seemed to remember having a problem getting new ones. I think they but a higher shoulder around the socket on the meter and the hole in it is smaller than average. The plug that goes in the meter has a 30mm long shroud and the shroud is 6.6mm OD with a 3mm plug hidden it. The other end of the lead is a 3mm socket in a 9.2mm OD shroud. If I can find some 3mm leads that are long enough I shall dump 'em. These are heading the right way however I just want 4mm plugs on the other end so I can use what probes I want and I'm not too sure if the shroud will fit.
I've tied testers.co.uk for leads, any other good places?
Cheers
Andy
Cheers
Andy
