I was wondering how long the plastic duct would last? Top job though!! Unfortunately due to my garage being a total dump most of my welding is confined to the outdoorsI think you'll find that the plastic tube duct will degrade & split quite quickly due to the UV content of the welding arc .
You can get 100 mm aluminium flexi duct from " Wickes " on line , it does not melt holes but it does reflect light unless you matt black spray it every now & then .
If it does not fit the flange/collar of the fan perhaps cut up some old 100mm /110 mm cleaned soil or vent pipe to make an insert and collar to fit , glue weld it to the fan unit .
That's the ticket.So, like this? (excuse the bad artwork - best I could do in ten minutes!)
All the crap and nasty fumes are carried by moving air without touching the expensive fan. I know we are probably not going to be using it to the extent that any of those fumes would affect the fan. ?Why make a problem for the future?Why wouldn't you just use that fan inlet instead of the modified pipework?^^
Someone with a brain may be along soon, but I think the fan would move 'so many' litres of air through a system. That stays the same wherever the fan is, pushing or pulling. However, using that air movement to draw extra air would increase the extraction at the welding site.Yeah fair enough.i would prefer more suction myself but i see your point
Ile ask the wife later iff its better to suck or blow...then come back with the answerSomeone with a brain may be along soon, but I think the fan would move 'so many' litres of air through a system. That stays the same wherever the fan is, pushing or pulling. However, using that air movement to draw extra air would increase the extraction at the welding site.
A little picture soon.
That wouldnt add up to extra air removed from the welding site unless the fan inlet was utilised for fume extraction also,you would thinkCRB said:Someone with a brain may be along soon, but I think the fan would move 'so many' litres of air through a system. That stays the same wherever the fan is, pushing or pulling. However, using that air movement to draw extra air would increase the extraction at the welding site.
My money is on the answer being a black eye or a thick lipIle ask the wife later iff its better to suck or blow...then come back with the answer![]()
My money is on the answer being a black eye or a thick lip![]()
shes in the other room,ile email her.In that case I retract my earlier guess and change it to a reply of "Why don't you come in here and find out?"shes in the other room,ile email her.
no i knew you meant someone who was taught this stuff,not bluffers!Someone with a brain may be along soon
Edit: The first few words sound a bit rude, I mean a clever chap to prove me wrong probably, not a disparaging remark towards 'wheresmejumper'
A lot of flux recovery systems are built in this manner, it's a very effective way to draw, if it pick flux up behind a sub arc run it will draw any amount of fume no issue.Someone with a brain may be along soon, but I think the fan would move 'so many' litres of air through a system. That stays the same wherever the fan is, pushing or pulling. However, using that air movement to draw extra air would increase the extraction at the welding site.
I used tapering plastic plant pots as reducers.just cut to sizeGood work. I'm in the process of making one. I got a 10 inch extractor from machine mart of the reduced clearance shelf. Got some alloy flexible rigid ducting from ebay for £15. Just waiting for some 10" to 6" reducer to arrive.
