I have two 10mm top plates (each 6' x 16" ) that need cleaning up to provide an acceptable level of finish for a bench top.
I sort of recall recall seeing a reply in a thread on here somewhere, where the person used some additive (not wd40) but possibly something similar ? to keep the top from rusting again. Can anyone offer some advise for how I should proceed with my bench tops please ?
The bench which I put together last weekend, is going to be used outside (under a permanent lean-to roof) & it is actually very stable. I know its probably a bit amateurish by comparison to the box section fabricated benches on here, but I cannot weld as yet & so I needed a table / bench to get started on. (I can always upgrade to a fabricated design when I can weld …. using the same top plates !)
