Thats the point. THis is what they wrote.Presumably your drilling measurements for the holes for the locating pins would need to be dead accurate?
Or is the ring assembly a 'stand-alone' gadget?
I can see that part mate but its the holes he has drilled into the chuck. He actually says they do not need to be accurate when I would have though they had to be spot on....The chuck jaws are tightened on the ring to keep them against the scroll and the grinding bit is passed through the jaws to reface them. Each pass the top slide can be moved to skim a little more off until the jaws are refaced.
http://www.chaski.org/homemachinist/viewtopic.php?p=173660#p173660 This might help to see what they are saying..I guess you could tension the jaws against the scroll by putting something in the chuck and then drill using the same head as is being used to grind the jaws above? The cross slide would need to be locked off. Are chuck jaws not hardened though - I presume these must be soft jaws, unless they come per-drilled?
The picture here shows a chain saw sharpener (25K RPM) mounted to a Aloris post. Simple but very effective.
The pins on the front of this chuck are 1/8 dowels, and the holes were drilled with a 1/8 masonary bit (with water cooling) and exact hole location is un-necessary, as the ring loads the jaws irrespective of location.
Mark the contact point of each jaw with a felt tip marker.
As you grind, you will see the contact point move outward as the ink is ground off. as soon as all ink is gone, spark out , and quit."
Does not make sense to me..
Thats what I was going to do BUT I think that assumes the outside it accurate. IT possibly is better then the internal side of the jaws to be fair . They are bellmouthed. I know I am not gonna get perfection but I would like better work holding.wouldn't it be just better to make a ring and hold it on the outside of the jaws?... doesnt make too much sense to me in this configuration...
Thats what I dont follow. If those pins are out surely it will be out when its been ground or bored.Ah, yes, I see it now. As it says, the ring just loads the jaws - it doesn't matter where the pins are.
Thats also why I like this idea. http://lathe.com/tips/chuck-jaw.htm How to get it made accurately I am not sure yet.No, because that would load the jaws the wrong way against the scroll, if I understand it correctly.
I think I follow what you say but my age is against me sadlyThe ring isn't rigid enough to hold the jaws in a specific position. It is the scroll in the back of the chuck which is holding the position of the jaws. The purpose of the ring is just to tension the jaws against the scroll (take out the backlash).
I think I follow what you say but my age is against me sadly![]()
Thats how I see it, the inside of the scroll's machining of it's 'thread' denotes the jaws separate positions when locked onto something, anything, even a piece of steel tube would do, what you are doing is paralleling each jaw and equalizing the distance between the inside of the scroll to the object tightened in the chuck.The ring isn't rigid enough to hold the jaws in a specific position. It is the scroll in the back of the chuck which is holding the position of the jaws. The purpose of the ring is just to tension the jaws against the scroll (take out the backlash).
You could do it on a drill press, but because it is only to give the jaws something to grip, you could be a millimeter out and the three points of contact would average out.View attachment 58625
aarrgghh me heedYou could do it on a drill press, but because it is only to give the jaws something to grip, you could be a millimeter out and the three points of contact would average out.
