Cheers, Wallace. The air stays on for a couple of seconds after releasing the trigger.
To say that the manual was not exactly a treasure trove of helpful information would be an understatement!
Good point - I should have been clearer than when it was working, it certainly wouldn't create an arc in thin air, so I guess it doesn't have pilot arc.I didn't think these machines had a pilot arc, I fire mine in air to check the pressure gauge on start up and there are no blue flames or flashes from the torch.
and it certainly doesn't seem to bother my consumables, ive had the same set on since I got the thing in November and have done a fair bit with it.
you must have a pilot arc then, the cut 40 / 50 machines of Chinese origin don't have this feature so don't hurt the consumables, they only createMy Hypertherm 30 will create a small arc for a short period even if fired into the air and that's what ruins the consumables.
@J.B. Welding and @scotty41 , reading back through this thread I'm a little confused:
You're actually agreeing with other but bickering about it?![]()
Guess it really depends on the type of machine you have as to weather damage occurs or not at the tip.
