mr mechanic
New Member
- UK, Dolgellau
Hi there, maybe somebody can give me a bit of info here.
I have a wolf air compressor, 3HP 14cfm 90 litre (this one to be exact: http://www.ukhs.tv/Workshop/Air-Compressors/Dakota-14-CFM-Air-Compressor) and was hoping I could do a few modifications to it. As it's a 3HP motor it tripped of as soon as I turned it on (I was expecting it to) and so was wondering would it at all be possible to change the motor on it from 3HP to 2HP, something like this one:
http://www.ebay.co.uk/itm/ELECTRIC-...al_Components_Supplies_ET&hash=item2ec03bf7f5
Would a 2HP motor have enough torque in it to turn a pump of this size or not?
I know the best solution would be to rewire the shed electrics so that it can handle the compressor but that's not really an option at the moment. One day i'll do it
(maybe!) but that would limit the compressor to being stuck in the shed and being able to move it around would be quite useful.
Also while we're at it it's rather noisy, so would swapping the motor from the 3000 rpm one that's on it for one that spins maybe 1400 rpm reduce the noise. Obviously I understand that this would give less output if at all it worked, but that's just it; would it work? In theory (or mine anyway!) it would just take twice as long to fill the tank (and the pump might run cooler?)
(maybe!) but that would limit the compressor to being stuck in the shed and being able to move it around would be quite useful.Also while we're at it it's rather noisy, so would swapping the motor from the 3000 rpm one that's on it for one that spins maybe 1400 rpm reduce the noise. Obviously I understand that this would give less output if at all it worked, but that's just it; would it work? In theory (or mine anyway!) it would just take twice as long to fill the tank (and the pump might run cooler?)
. That's what's putting me off wanting to completely upgrade the supply. It's not really worth it.
