SmartWerks
pre-moderated
- chester
If its the strut mount bolts it will be 1.25 pitch, had enough Japanese cars to know. Get a pitch measure for feck sake
Use bolts as pitch gauges. Grab an M6 or M8 and you can be fairly sure they are 1mm and 1.25m pitch.
You can measure it if you have a ruler, or caliper, get the threads clean and then roll a bit of paper round the
thread, it will leave nice marks and you can measure the pitch.
Careful on that one most seat belt mounts are 7/16 unf even on japs and they will screw into metric fineSeat belt mounts
So that's what the 8.8 is on the head of boltsWARNING you need to know what strength grade that nut is before replacing it with a new one.
I will more or less guarantee it's not 8.8 or they wouldn't have used a fine thread in the first place. It could well be 12.9 and will take considerably more load than a 8.8.
. Is it tensile strength - 8.8 : 88,000 PSI?
Metric bolts
8.8
Class 8.8
Medium Carbon Steel, Quenched and Tempered
All Sizes below 16mm
580 Proof Load MPa
640 Min Yield Strength MPa
800 Min Tensile strength MPa
16mm - 72mm 600 660 830
10.9
Class 10.9
Alloy Steel, Quenched and Tempered
5mm - 100mm
830
940
1040
12.9
Class 12.9
1.6mm - 100mm
970
1100
1220
Stainless markings vary. Most stainless is non-magnetic.
Usually stamped A-2
A-2 Stainless
Steel alloy with 17- 19% Chromium and 8-13% Nickel
All Sizes thru 20mm
210 Min.
450 Typical. Yield Strength MPa
500 Min.
700 Typical. Min tensile strength MPa
Tensile Strength: The maximum load in tension (pulling apart) which a material can withstand before breaking or fracturing.
Yield Strength: The maximum load at which a material exhibits a specific permanent deformation
Proof Load: An axial tensile load which the product must withstand without evidence of any permanent set.
1MPa = 1N/mm2 = 145 pounds/inch2
As Pete says 10mm thread X standard is 1.5, standard fine is 1.25, fine is 1.00, super fine .75 (not common).M10 x 1.25 and M10 x 1.0 are both fine threads.
So that's what the 8.8 is on the head of bolts. Is it tensile strength - 8.8 : 88,000 PSI?
Add to that 1.5 which I think is what we all have hundreds of.. Lol and it gets confusing.check the thread carefully... metric fine comes in with 0.75,1.0,1.25 pitch varieties... just to keep it interesting...
FWIW, my dad had a gib key puller that specifically came with low tensile bolts so the bolts would snap before the head of the key does.the totally useless 4.4 which I would not advise to use on anything on a car.
. We ended up using a big puller to pull the whole flywheel off with the key in place, it got a hairline crack though because the key wouldn't budge
