Background - I am a welder/fabricator working for a small company in mid wales. Because of this CE marking coming into force the company has had to appoint an RWC and because I had the most technical knowledge (being the youngest and left collage only 10years ago, and generally having a passion for welding) the boss decided that I was best suited for this roll. So I got sent on the RWC course last week, even though I did well on the course (got 90% in first paper and 98% in the second) and took an board a lot of information, it was only a two day course and have no experience of this job roll. So I am lacking a bit in confidence and still have a few questions with not really anyone to ask. As we are a small company and don't really do any work that falls under EN 1090 at the moment (the boss wants to have the CE marking as a future proffing aspect) once I have written the pWPS's and got them qualified I won't really have much to do after that, and as there is only myself and one other welder that will be doing CE work I won't even have much inspecting to do. It's just going to be getting from where we are no to the point where everything is set up that's going to be the hard part. So any info and advice I could get would be very much appreciated. The questions I have at the moment are to do with material selection, getting the pWPS's qualified and whether the 5% NDT can be done in house by myself or if this needs to be done externally?
There is such a shortage of RWC's (Particularly those who can do EXC 3 and 4) once you have gained some experience there could be a lucrative career path for you?
What about material selection?
pWPS's get qualified by welding a WPQR for a NoBo, they will attest the validity. Then you basically have to redo your WPS's so to have an as large as possible workfield (eg a fillet weld from plates 4-40mm can be a single WPS, but need multiple WPQR's to cover the whole range).
The person who does NDT needs to be qualified for the methods he does (PT, MT, visual). If you get certified, you can do it yourself.
You will need a FPC manual for your workplace, and several forms/procedures. Most likely, someplace in the UK (like the BCSA, or an independant IWE consultant, ...) will sell the templates. Cost a bit, but you only have to fill in the blanks and check what's applicable for your particular situation.
Fair play, you've done well there!
But...Sounds like your boss has gone around it the hard way and spent too much money.
The RWC doesn't have to be an employee of the company. Once your procedures are approved, welding manual signed off, and the welders coded, completed weld inspection tests, the only requirement for the RWC under BS1090 is to 'pop in' to review and sign off the general standard of work being produced - twice a year minimum I believe but I'd need to check that.
We employ a subcontract RWC who is on the end of the phone if we need her, and available to sort out any additional WPS's we need doing, as well as testing any new welders that start. Because we have spent a fair few quid on WPS's and welder testing etc they are on a free 'retainer', so there whenever we need them. They do this sort of thing day in and day out, so cheaper and a better job to get them to do it rather than you, with respect, floundering and trying to sort out what you need to do.
Other than that it is just a formality that you 'have' an RWC and of course a name to put on the 1090 certificate.
I see of a lot of fabricators who have done this - no need, but seeing how much miss information is out there regarding CE Marking, not a surprise really. Bigger companies of course, it may well be worth them having their own RWC.
1) So my question about material selection is, going from table 6 in the pic would I be right in thinking if a fillet weld is done on 30mm then that would qualify all fillets 5mm and above?
2) So I would basically right a pWPS, weld a test piece in accordance to that and if everything looks right then write a WQPR for the NoBo to test?
1) yes, a multi layer fillet weld on two pieces of steel each >= 30mm will qualify all multi layer fillet welds on steel >= 5mm thick
2) you write a pWPS for that, weld a piece for a NoBo, they make the PQR and you can write WPS'ses based on that PQR.
There's a change though on your document: Table 6, second row (3 < t < 30) qualifies 0.5 t (3 min) to 2 t (not 1.2 t), see ISO 15614-1:2004/Amd.2:2012
no problem :-)
I'm an independent (since beginning of 2014) certified welding engineer, with some years experience in railroad, large metal fabrication and off shore (and quite some hands-on experience).
I am consulting mostly for firms who use high-end steel types (welding and repair procedures, design and calculation, heat treatment, ... mostly for piping), but lately I've jumped on the EN1090-bandwagon as there is a huge market for that at the time being. and a lack of RWC's.
Please ask your questions here (as opposed to PM), as sometimes there might be differences Belgium <-> UK, that I'm not aware of and that other forum members might know or maybe other guys can help you out as well.
So everyone can benefit - that's the main reason of a forum, right?
