Hello, right I recently gave my car to a welder to sort out as it failed it's mot on a load of welding and, I'm still learning so thought its best for the pros to do it , well he had to fit new panels and make panels as it was a rust bucket it had stood for 10 years, so I bought some panels and he set to work, well he has seam welded the structural parts of the car but the outer panels like my rear arch he has spot welded it, along the whole panel so it's like dot space dot space dot, he has told me he has had mot testers look at the car and they have said it will pass it's mot, he also works at a mot centre, I will be getting the car fully resprayed so I'm sure the painters will have to rub down and finish the car off, but is it ok for him to do that I mean the spot weld, I'm going to take it back to the tester at another garage who failed it on a load welding so I can make sure he has done a proper job I shal also point out that anything that has concerned you as off the welding please fail it if it's not up to the roadworthy standard, hope it's ok tho just want to put my mind at ease with you guys, all advice appriciated in advance,
