Hi, I'm looking to upgrade my compressor from a small 50l to a larger more capable unit. I was looking at the one below:
I copied and pasted the above from the shops website, is this a good compressor, or are there better available for the money? It seems to be being promoted on the basis of quality. Are ingersoll rand better than a clarke or an SIP compressor?
Thanks
Ingersoll Rand - 3hp - 200 litre - Belt Drive Air Compressor
This Compressor by Ingersoll Rand is their flagship. No brand stands for build quality and long life like Ingersoll Rand, its an investment that won't disappoint you.
Fixed Receiver Unit
The belt driven fixed receiver units are available from 4 to 7.5 kW and are designed for intermittent duty applications such as framing, carpentry, automotive maintenance and general maintenance requirements. These compressors include cast iron cylinders, a balanced belt wheel for smoother running, auto start/stop regulation pressure switches, TEFV motors are come complete with a factory fill of lubricant.
Features
Tank (litres) 200
Max Pressure (barg) 10
Nominal Power (kW) 2.2
Piston Displacement (l/min) 350
Length (cm) 45
Width (cm) 146
Height (cm) 90
Weight (kg) 102
Voltage/Engine 230 - 1 - 50
Fixed Receiver Unit
Features
- Twin cylinder two stage pump units
- Inlet air filter included
- DOL with Star / Delta starter option
Tank (litres) 200
Length (cm) 45
Width (cm) 146
Height (cm) 90
Weight (kg) 102
Thanks
thats the best ive heard yet star delta starting on single phase 240v i wonder how that works
