Richard.
- Cambridgeshire
For work Mind I've no need for kit that precise at home.I'll be buying one of those I've heard they are really good
Your right Paul I guess I'm just phonetic about it because I like accuracy and I buy my own gas so I don't want to be using any more than I have to.People seem to get hung up on having the perfect gas flow rate.....For MIG, and even TIG to a degree, i don't think it really matters is you are a few L/M either way?
My job requires that sort of accuracy with all welding conditions and I take that same level of accuracy when welding from my own gear. I am technical support for a welding company and I do a lot of trials with conditions , consumables, process,equipment, gas, and accuracy is vital, also I'm a bit of a perfectionist with my own work and I like things to be bang on.A question for you: why do you need such an accurate flow rate?
Is it because you have to record that information for regulatory reasons or when you're running twenty welding stations the costs add up or something else?
Not a snide comment, I'm just a hobby welder so if it doesn't look like worm sign then I'm happy so I'm genuinely interested to know.
Yeah some people don't give a t0$$ if it's not costing them. Good move with the multi stages.The right attitude to have too.
Before we had twin stage regs i'd often find regs with sky high flow rates due to the speed at which we empty cylinders - never affected the welds, just my pocket.
I'd reckoned on it being cost related for exactly the reason you say but I'd not realised that there could be a strength issue that is unknown if you don't have the correct flow.It is normally for the benefit of the guy who signs the cheque for the gas at the end of the month, regularly see flow gas rates well over 20 ltr/min, highest I've come across is 75ltr/min. If you think about it, 20 guys all running at 25ltr/min are wasting around a cylinder of gas per hour
Also excessively low flow rates will allow nitrogen ingress into the weld pool which will reduce the strength in and around the HAZ long before you see porosity in the weld. I totally agree with the comments about people getting hung up about the accuracy of flow rates, more so with MIG/MAG than TIG and root purging
View attachment 57216 Just below 6lpm on the reg View attachment 57217 just below 5lpm on the pea shooter. I'm sure they are both accurate where they are but there is a discrepancy somewhere. My reg was very expensive and every joint is leak tested. My line is over 2 metres long I'm sure it's possible at these low flow rates a reduction can be achieved through the line.
Before we had multi stage regs i'd often find regs with sky high flow rates due to the speed at which we empty cylinders - never affected the welds, just my pocket.
What do you mean, it not like computers where the more times you press the button the faster it works? GuttedIn production welding it is common to find the flowguages maxed out (40+ lpm) as they believe the higher they can turn something up (weldsets included) the quicker they can finishwe fitted tamperproof flow regs to all our manual welding booths.
