Dougal McGuire
New Member
- Wales, Powys
Hi, first post so here it goes.
Recently I was fortunate enough to buy this drill from a local farm(hence the straw on the floor in the pictures). The drill comes with a single phase 1/2hp motor which I doubt is the original, and it seems when they replaced the motor they didn't bother wiring in the reverse. I would like to restore the drill so that everything works as it should. Any help or advice on how to go about rewiring the switch/motor if it's at all even possible would be much appreciated.
On the motor it says to swap over the blue leads in motor terminal to reverse, so would it just be a case of wiring them to the switch??
Also I'm missing the high/low gear lever and cover, if anyone knows of one.
Thanks in advance.
Thanks in advance.
