CRB
No facilities to make them ourselves.
Why not make them?
Why not make them?
I need to get hold of some more tee slot nuts for our radial arm hole-chewer. Sizes below are in MM. (May well be imperial??)
You have to improvise if the item/s are imperial or odd sizes?
Block of milled steel to lower half of T nut clamp size drilled and tapped thread size(which can be got anywhere)then a square nut to size of slot and thread size.
You don't even have to weld the square nut to the milled steel block because the moment the bolt starts to clamp the job piece it will lock up
I Just weld two nuts together normally, assuming there is enough height in the bottom part of the slot- there is on all of our machines.
I would do (and have done) similar myself until I took a class on scraping and machine rebuilding earlier this year. In that class I learned that bowed mill tables can be the result of repetetive tightening, especially over-tightening, of tee slot nuts essentially 'peening' the underside of the tee slot and causing a build-up of stresses that bend the table. In one example the tutor claimed that a table was sprung back flat by running a clean-up pass through the slots with a tee-slot cutter. I can only imagine that using a hex nut in a tee slot with it's profiled face instead of a longer tee with flat faces would result in higher concentration of forces and an exacberation of the condition. I wouldn't do it on that basis.
