it would grind things verry accurate providing there small as the surface aeria of the disk will soon wear out
u obviously dont know how accurate a shaper is .its on par with any decent miller if a decent grinding wheel was fitted on the shaper head it would be no diffrent from using a toolpost grinder on a latheBrightspark it is only going to be worse tolerance than the shaper machine before the junk was added on the end. With all the will in the world a decent shaping machine will not match a decent surface grinding machine and that's before you strap a angle grinder on the shaper.
Admit it, you just don't like Shapers!Brightspark it is only going to be worse tolerance than the shaper machine before the junk was added on the end. With all the will in the world a decent shaping machine will not match a decent surface grinding machine and that's before you strap a angle grinder on the shaper.
Well, maybe an angle grinder isn't that accurate but I see no reason why a better grinding spindle wouldn't be a good idea on a shaperIt's a angle grinder with very little in the way of precision mechanically. The disc will flex and vary it's pressure across the work piece. There is no cooling so limits it to thick stuff.![]()
