whatever your hourly rate u want + expenses gas rods consumables ectHi guys. Do u know how much would I charge for 1 inch of stainless steel tig welding? I don't know nothing about prices. What about tig welding aluminium? How do u charge customers for small projects? Cheers
Well this would be pretty dependent on whether you ordered this specifically to do that job and as dan rightfully says are you going to use the other half in order to pay for it. It's a tricky one and you need to be fairly sensible and competitive. You may end up shooting your self in the foot if you start charging excessively for things you don't use but you don't want to end up paying for stock to sit there either. The worst thing you can do is start making a loss because your not covering your own costs nicely.If you order a sheet of steel for a job ,and only use half do you charge the customer for the full sheet ?
Do you what sort of hourly rate should you charge?What sort of money you mean? How much
It doesn't sound hard, If you tell me the numbers I'll make a formula for you.Be nice if someone had some calcs on weld type and lengths though, I doubt its too hard to formulate
Weld volume calculator is the term to search for, second hit should be an excel calculator for butts and fillets. Some consumable brochures also have a bunch of tables in the back that provide weight per unit length for various weld joints/root gaps/preps (usually all based around mild steel) along with process efficiency constants, densities of various different alloys and the formulas themselvesBe nice if someone had some calcs on weld type and lengths though, I doubt its too hard to formulate
