Hi,
I have a cheapo 140 amp arc welder, and when you turn the amps down the buzzing gets really loud, is this normal or should I have a look inside to check everything is ok?
If it is normal I was thinking of building a new case for it which would be totally water tight and submerging the whole lot in some veg oil which should have a two fold effect 1, less noise 2, should keep the welder cooler for longer so it wont cut out as much.
I have seen it done with computers and it works well, as long as there are no moving parts it should be ok
What ya'll think of that?
