This might sound a bit silly but I need to drill a hole and I need to know if it's something I can attack myself of leave for a pro.
I am currently working on my mk2 escort and I'm planning on fitting a 1.7 zetec se engine from a Ford puma, now this is where the hole comes in, the 1.7 is the only engine in the Ford range that has no provision for a spigot bearing in the end of the crank I think it's currently 17mm and I require a hole 21mm. The crank is made of steel and is hardened.
I've asked my local engineering shop and he was going to charge one hour labour to bolt it to his drill ensuring it was level etc and another to drill the hole, on top of that if he didn't have the right size of drill I'd be charged for that too. Now that I could deal with but he also asked for the block to be bare ie no head etc and to be clean which I can understand to an extent but I'm on a tight budget and cannot really afford to spend the extra money on a head gasket, cam locking tool and what ever else I need on top of his bill for the work that's to be done.
I know that the hole can be drilled with the engine complete I just would like to know is this the sort of job that I could do myself or should I let somebody else do it. Have access to a pillar drill if that going to help?
Thanks for taking the time to read this
