I recently picked up this beauty. I could not resist. It had been advertised in the local paper about 6 months ago and I went to have a look at it. No motor persuaded me to not bother at the price he wanted. He had tried to sell it a couple of times after that but had no takers.Then lo and behold its at the auction last week. I left a bid and was the lucky punter. Boy its heavy. Luckily they have an overhead crane so getting it in my LDV was not too difficult. Getting it out was a little bit tricky but I removed the pump and some pipes and stuff and managed to offload without too much trouble.
The pump is a twin cylinder Broom & Wade DCL15, bore 25/8 and stroke 2in and normal rpm 950. The tank was supplied by Cotton Bros from the Crown Works here in Stoke on Trent at Longton.
As you can probably see there is something amiss with the blowoff valve(red tape holding it together). A spring seems to be missing at the very least. It has two belts and would think that the original motor was a three phase unit. I was wanting to put a single phase one on. What rating do you think it will take? I had a scan of ebay and on there there is a Broomwade compressor with the same pump as mine. The seller reckons it has a 2.5hp motor on but he reckoned a 1hp would do. Any advice on that and the broken blowoff valve would be much appreciated.
