Barlidge
- Langford, Bedfordshire, UK
I know its not welding but of all the forums I visit the variety of knowledge on here always amazes me.
I have three 30v SMPSs used for powering an audio/video distribution system, they are about 10 years old and the system has been in use 24/7 since day 1.
A year or so ago they started to fail, the symptoms would be that the supply would emit a low pitched cyclic whine and fail to boot properly while the system was plugged in, if I unplugged the supply from the system the supply would then boot up allowing the system to be plugged back in and would function normally until the next power outage. In this failed state the output was only 12v.
One has failed completely and will no longer boot using the above procedure.
One is well on the way and will still boot as above but takes approx 5 minutes.
One is in earlier failure mode and will boot as above within 20 seconds.
The whole system although good was very expensive and replacement power supply's are approx £180 each
and I am struggling to find a 30v 4A output generic supply from anywhere. I have also rang around a couple of local electronic engineers who have been reluctant to take a look. I have looked for the obvious such as dry joints, bulging caps or any other visual sign of failure but none apparent.
Is there anyone one here who could help in any way, either by looking themselves (beer tokens of course) or by advising components to change. I have attached a pic and also have an audio file of the cyclic whining increasing in tempo until the supply finally boots but I cant upload an MP3.
Many thanks.
and I am struggling to find a 30v 4A output generic supply from anywhere. I have also rang around a couple of local electronic engineers who have been reluctant to take a look. I have looked for the obvious such as dry joints, bulging caps or any other visual sign of failure but none apparent.Is there anyone one here who could help in any way, either by looking themselves (beer tokens of course) or by advising components to change. I have attached a pic and also have an audio file of the cyclic whining increasing in tempo until the supply finally boots but I cant upload an MP3.
Many thanks.
