Hi, had some major issues over the last week with porosity, I started welding some saddles onto an axle, ran a nice bead then ran out of gas. Went and got anoher bottle then jot a porous weld, I blamed it on the oil impregnated axle case, so I ground it out, cleaned the inside as best I could but swapped to mig, all welded up no probs.
Had another job to do, basically a 40mm EN8 turned to a stub and welded to 3mm plate. I choose EN8 as a medium strength steel. I bored the 3mm plate and intended to weld both the stub from both sides. 3mm plate and stub was ground back to bright and de-greased wth brake cleaner thoroughly before I started. I could not have got it cleaner. Welding the backside immediatly I got porosity, crackling, spitting and chasing an air bubble in the pool. I thought maybe the gas was ifffy, So I topped immediately, ground my tungstem (swapped from red to gold too and on a fresh wheel ) same happended again.
Was using ER70S-3 rod, about 90a and 10lpm. I ran beads on the 3mm plate (mild steel assume EN3B) alone, perfect. So it appears to be the EN8 material. Its been turned, using carbide tools and water based coolant, and I wondered if this has contaminated ? but even welding on un-turned section yeilds porosity. Whats my probloem here ? is EN8 the wrong material ?, could this be from the turring ? can't be the rod as it's occuring even before I dip ?
It then goes on to spout some utter nonsense about it reacting with (the noble gas) argon
