even though it's obvious how the can hovers in mid air
Well could you explain it to me please
So you canWell could you explain it to me please
AH if you look close you can see the string
, defeats the point rather.
No there's no string or wire. It's magicSo you can, defeats the point rather.
Get some pebbles glued around the water pool to hold it down would help
or even remove the photo editing![]()
You could go one better here - have a single large pipe that holds the can up, which pumps water up through it (T-Piece at the bottom somewhere and enough blanked off pipe there, or a heavy plate to sit at the bottom of the pond) and you've got a cool water feature for a pond.
Cracking ideas! Will think about that when I've got time.If you were proper keen you could go even further -
Have a clear pipe holding up the can by its spout, so as the water flows down, over the clear pipe, making it invisible (hidden in the water stream).
Then pump the water to the can through the inside of this clear pipe.
It then looks like you have a watering can, hovering in the air, with water flowing out of it.
GO on with you, tell the truth, look at MY picture closely ( click to expand) you can see the string. It's tied to the handleNo there's no string or wire. It's magic![]()
,oh yes through the spout!!!
my dad made one of those, but it was a single tap not connected to any pipe apart from the glass one up to the outlet of the tap it just sat there on a columb of downward flowing water. He was the superintendent of the local water authority and had it as a display in the entrance foyer.
