That is the plan but I was wondering if anyone had any knowledge of this bit of kit so efforts could be a little more focusedWell the first port of call is stripping it down to see where the wear is obviously.
It's quite an old machine and takes an odd size of belt that are difficult to source, 560mmDon't overlook the simple things... Junk belts will have similar effects.
Isn't it better to conduct some research and have a vague idea of what's going on before taking things apart, some things might not be so obvious, even when opened upI don't see the logic in waiting around for someone to say it might be this it might be that when you could have it srtripped within the hour and finding out what it is.
the plastics might be fractured it does happen specially where a bearing is encased,the B&D sanders are known for this and the case just shatters when a knot is hit.
Can you recommend reputable supplier
How much are they for Al oxide?I can supply 75 x 560 or 100 x 560 in lots of 10 belts per grit in Aluminium Oxide or premium Zirconia (best for steels).bad joints will cause vibration,cheers,john.
