brewdexta
The biggest tool in the box
- UK
I want to turn on the Toylander's brake lights when foot brake is pressed. Currently they are operated by a tilt switch so the lights only come on when there is deceleration. So if the kid is stood on the brake and the accelerator burning the motor out there is no indication. Also with all the hills near me the brake lights will be on all the time
The foot brake mechanism on the Toylander is integral with the hand brake, so if you operate the hand brake the foot brake goes down. I don't want the brake lights to come on with the hand brake so a switch under the brake pedal is out unless I put another switch on the hand brake lever in series that opens the circuit.
One thought was putting a 20mm square pressure switch on top of the pedal, however searching for pressure switches obviously brings up compressed gas type switching and pressure mat is usually much bigger than 20mm sq and used under carpets for security etc.
Anybody know of a suitable switch or have an alternative idea?
Cheers
Andy
Cheers
Andy
So anything that operates on the pedal press is going to operate with the handbrake as well ?
