Nice. I've seen one seriously cheap in a local Cash Converters. I don't need to shape much in the way of metal thickness. 2mm should be more than enough. Just need to find a few metal cutting blades that will fit. Can't recall the make or model.
There is no reason why you shouldn't cut say Ali and other soft non ferrous on one, not really the thing for steel plate though
but thinnish stuff is easily done if you aren't going at it like a loon.
, so it's a point noted from experience).
There is very little than you can do with a jigsaw or scroll saw in a fab shop that cant be done with a better and quicker / easier with another tool IMO but at times I have used such ways. On 3mm thick ali one could be quite handy but between that and laser cut?
The limitation of any tool, within its comfort range, is generally user and not tool based.Well ... I went and got it. £25 (one recently sold on eBay for over £60)! I beat another customer to it by under minute ... phew. It's a Nu Tool SS16 405mm jobby in solid steel. Only a 94 watt motor, but it's what it will do rather than how fast it can do it that matters to me. So far the blade appears to run truly vertical as well as being aligned with no detectable play top or bottom. Just need to get a few 130mm pinned blades in various types/tpi and it's all systems go.
Anything can be done with almost anything. A guy dug out of Alcatraz with a spoon, a kango hammer would have been quicker but the spoon suited his purpose and it was all he had and time wasn't a big issue to him after all.
This is true,I mean I have put a file in my reciprocating saw before today to file some aluminium plate side.![]()
Using a tool for its designed purpose is one thing, but using a file when you have no control over pressure on the backstroke is just plain wrong. That's a quick way to knack a file.
Not disagreeing. Just trying to point out that it's not unrealistic to use items for other than the generally accepted purpose is all.The limitation of any tool, within its comfort range, is generally user and not tool based.
