I decided to replace the fuel in my mobile generator (Pro user 2.3Kva petrol generator G2300 with Honda engine). I do not use it much as it sits in the van and is for when I might need electric when out and about). It has been a pig to start the last year or so but a squirt of the magic can gets it going. I decided to use the Aspen stuff. Its £20 for a 5L can but it can last up to 2 years without going off. I have just put my second carb in for sonic cleaning due to the petrol going off and gunging the carb. First was my lawnmower. It would start and run but only at full throttle. Then my mobile compressor would not start. The petrol stank when I drained it. Again these only get used rarely.
So drained and refilled the generator and it started straight away and the volt meter showed 230 Volts. Switched on the breaker and plugged in my Dremel and nothing. Accessed the wiring and "con" checked the lot and everything seemed fine. Put it back together and tried again. Nothing. I then looked at the Dremel and noticed that the earth pin was plastic and the wiring was only two cables. I then decided to try my angle grinder on the generator and bingo all okay. So I am assuming these generators need to see three wires at the plug. Is that for safety and does that mean that any tool that I assume is doubly insulated and uses only two wires does not work on these generators? I am not an electrician but can normally work my way around the simple stuff by the way!
Regards, Michael T
Regards, Michael T
