BrokenBiker
- Newport, South Wales
never really.understood it, is it just the same as brazing but with a mig gun?
From what I understand it is just mig with the wire made from the same compositon as brazing rods although mega expensive and likes to fold up and best suited to a hand held wire feed torch. Saying that never seen it for real just what I have read/heard.
Like most harder (stronger) flavours of steel it has enough carbon (and other stuff) in it to be hardenable by heat treatment. Generalizing MIG is a fast process with lower heat input than TIG and both are much lower heat input than oxyfuel. Because you put less heat into the part with MIG the surrounding (relatively cool) area effectively quenches the weld. What happens when you heat and quench a med carbon steel? With TIG the higher input results in everything getting warmer and/or the heat spreads further so it takes to longer to cool down and the result is less brittle. That said if you speak to some people in the EAA they'll point out that if you subject some weld coupons to fatigue testing TIG often lags behind oxyfuel with regards to fatigue life unless some pre or post heat was used
