AndyStobbs
- North West England
Can any of the electrical installers explain why it catagoricly states in the instructions that the metal cooker hood is not to be earthed? Seems counter intuitive to me?
Indeed and if you have a earth live fault else where then you might get a live cookerhood!
^^ wot he said. double insulated appliances should have no possible way where any metal part that you can touch can give current a path into you or anyone else, hence the lack of earth cable as it isn't needed.
Isn't that backwards, the idea is the Earth rail removes the potential from faulty electrical devices? I understand double insulsted and all that, but couldn't see why a metal surface shouldn't be earthed for good measure. Think I'm with sidewinder.
and the cables are double insulated as well so its hardly likelyThe two core wire runs against the metal, there is a possibility it could rub through given time and vibration.
providing u have rcd protection at source the main services are bonded eg gas water and oil supply no other bonding is required the silly season on bonding is now not nesesary thank godSo does that mean convention is moving sway from cross bonding?
the silly season for bonding everything metal in sight has ended thank god .u used to have to bond all metal tables and rails and sinks together in industrial kitchens
it possibly was. time fliesCan you recall which edition that was in? 15th?
you seem to be missing the point, double insulated appliances are designed so that if a fault did devolop everything is insulated then encased in plastic so no way of it becoming live unless someone tampered with it purposly with the aim of causing injuryUnderstood, can totally see that logic with a device with plastic cases. Think. I would feel safer knowing a metal object was earthed - just incase a fault did develop in that object. It would be very very very unlucky for a fault to develop inside an object and also have a poor earthing circuit at the same time. But seems less unlucky for an un-earthed device develop a fault and the first thing you would know about it was as it ran down your arm.
No they aren't, they are insulated & sheathed.the silly season for bonding everything metal in sight has ended thank god .u used to have to bond all metal tables and rails and sinks together in industrial kitchens
.......... It would be very very very unlucky for a fault to develop inside an object and also have a poor earthing circuit at the same time. ........
