Hi guys...I have owned an SIP 130 turbo for about 10 years now...its been a love hate thing with it all those years...I dread getting it out to do a job with it sometime never knowing if its going to work ok...gives poor blobby welds with little penetration being the main problem,
I also have a 110 amp oil filled Oxford welder...it needs to run from a 30 amp supply with 30amp fuses or it will trip out the fuse,
I could never understand why the 130a mig is only supposed to run of the std 13 circuit,
Anyway as an experiment the other week before starting a big job on my old Landrover I made up a special 30amp ext cable 6mm twin and earth cable that I can run in the window to our 30amp cooker socket...gave it a try bit better,
So then just for test purposes I soldered a piece of 30amp wire across the welders 13 amp plug fuse and gave it another try...it then performed the best it ever has...I if fact did around an hour of welding with it set-up like this and kept checking cables plugs sockets for over heating...all seem fine,
So I'm at a loss now...why is it working ok running from the 30 cooker socket and 30 cable inc fuse when it suppose to run fine from the std 13 amp circuit.
Nick.
Nick.
