Steve Gray
- Southend on Sea, Essex, England
Hello everyone,
ive not had the need to do any kind of vertical up before, and know I will be covering it at college later in the course so thought id give it ago. As you can see im struggling! only had enough scrap to try 4 50mm long runs on 3 mm box, but all turned out the same
im using the same principles as I would if welding in the flat PA position, so slope angle of about 70degs and tilt that bisects the two peices to be welded, I also used a weave, as I read somewhere you need to do like a 'Z' pattern (I may be wrong??).
Anyway im sorry if this is really basic stuff for all you, but im hoping for some guidance
See pic below.
Thanks in advance
Steve
See pic below.Thanks in advance
Steve
